b20v not spraying fuel..??
Re: b20v not spraying fuel..??
use test-light hook it up to ur injector plugin(one at the time. then let somebody crank the car. u should see the light flashing. then u know u have power to u injectors. no power main relay. Check u fuses. 2 fuses inside, and ecu fuse under the hood.
Good luck.
Good luck.
