Battery / Wiring / Alternator problem
corona connessuer
Re: Battery / Wiring / Alternator problem
the car is in churchland? bring it by ill check it out
Hereeeeesss Beezyy!
Thank you God for all this info, and yes, its in churchland at an undisclosed location. Well, I live like 3/4 of a mile from where it is, because thats pretty much where it ended up. Mother fuck, I hate these cars. hahaha.
Ramey Built
Ok, that definitely sounds like a problem with the alternator or the alternator wiring. The electrical system isn't getting power except from the battery. I'm assuming the battery isn't getting charged then?
Hereeeeesss Beezyy!
Most likely. Text me again mother fucker, I lost your number.
braap braap
Yo foo'.
You get that multimeter. I'm trying to find mine. THIEVES!!!!!!!!!!!!!!!!!
I'm watching some gymnastics movie. Save me.
Hereeeeesss Beezyy!
I just called shawn, he woke up to answer oddly enough, and I told him to call back when he is awake. So Ima call in like 30 mins.
Slammedxpert
I had a similar problem, when my rear defrost wire was pinched it was grounding out against the body, causing some very odd stuff to happen.
Like when I had any kind of load on the alternator the tester said "replace alterantor, no voltage" replaced it...still sucked. It was also draining my battery within a hour of it sitting and it was wanting to cut off at stop lights. You could have a pinched wire somewhere as well? Get a multimeter and see if it has any current draw that it isn't suppose to have.
It could be the stupidest, smallest problem causing such a big one. Good luck.
