View Poll Results: Best High Compression Piston for B-Series Honda
JE/SRP
![](https://www.vadriven.com/forums/images/polls/bar2-l.gif)
![](https://www.vadriven.com/forums/images/polls/bar2.gif)
![](https://www.vadriven.com/forums/images/polls/bar2-r.gif)
![](https://www.vadriven.com/forums/clear.gif)
15
42.86%
CP
![](https://www.vadriven.com/forums/images/polls/bar3-l.gif)
![](https://www.vadriven.com/forums/images/polls/bar3.gif)
![](https://www.vadriven.com/forums/images/polls/bar3-r.gif)
11
31.43%
Arias
![](https://www.vadriven.com/forums/images/polls/bar4-l.gif)
![](https://www.vadriven.com/forums/images/polls/bar4.gif)
![](https://www.vadriven.com/forums/images/polls/bar4-r.gif)
5.71%
other
![](https://www.vadriven.com/forums/images/polls/bar5-l.gif)
![](https://www.vadriven.com/forums/images/polls/bar5.gif)
![](https://www.vadriven.com/forums/images/polls/bar5-r.gif)
20.00%
Voters: 35. You may not vote on this poll
Originally Posted by Insperation
What compression is good for daily street driven?? My GS-R Head will be tweak wtih stage2 Cams. Am thinking 12:0.1
What stage 2 cams will you be using?
Originally Posted by 1badITR
Many regard CP as some of the finest pistons for the money right now. I run them in the R.
I agree. Darius at CP used to head up piston design at Ross, and now he leads the sport compact division of CP.
Retired OG
![Wii](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![Wii](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
Originally Posted by JayDM
If tuned well, you can get away with 12.0:1. I personally would stick with 11.0:1-11.5:1. You can make 200+hp with that compression in 1.8 liter form.
SKunk2
卐 Walnuts
![EEK](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![EEK](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
Wiseco IB spec are nice pistons, and they get a lot of publicity (namely from Jeff at IB and Jerry) but there are companies that have been doing strutted, gas ported pistons for a lot longer with better results, finer precision measurements, and better wear characteristics. JE and CP to name two of the finest.
卐 Walnuts
Retired OG
Nice cams...those things will sing with those compression numbers. Do you have valve springs and retainers yet?
![Big Grin](https://www.vadriven.com/forums/images/smilies/biggrin.gif)
Originally Posted by EEK
ive seen a lot of dyno sheets..where the IB spec dyno's higher then other pistons
I understand why many people love these pistons though. IB does a great job "selling" their pistons. Like I said earlier, that technology has been around for years in NASCAR engines, Top Fuel engines, and even F1 engines.
Look at it this way...I can't even get information on the pistons that I got from JE. They are one off, custom slugs...they don't go around building websites boasting their products because its propriatary information that they don't want anyone else to know. Same thing goes for the CP pistons that I am having built for me...they won't tell me anything about them other than compression height, weight, pin size, etc.
Retired OG
ic ic..have you installed them yet? i like to see your dyno sheet after your set up is done
