Boost controller
Old 05-19-2009, 11:06 AM
Eh
NaIsGay's Avatar
NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay
Default Re: Boost controller
Originally Posted by sohc_mshue
nlr ams-500 or ams-1000 hands down one of the best controllers out there. I've had the greddy profec b spec II, an ecu controlled solenoid setup, and now the nlr ams-500. The closed loop control of the ams is awesome. I can also activate its different stages through the ecu. It features ramped control as well to help aid with traction.
Those can be tricky to use and i wouldnt waste the money unless he had a high hp fwd car or a REALLY high hp rwd car.... but thats just me, the 500 is atleast $500 bucks plus all the wiring that needs to be done.
NaIsGay is offline
Old 05-19-2009, 06:15 PM
iceguyb14's Avatar
iceguyb14 has disabled reputation
i have the turbosmart eboost 2 and its awesome. has tons of features
you can set the boost, the pressure that the wastegate starts to open at, the sensitivity, an overboost setting to if it gets to a certain psi it limits boost, also has several different set points so you can have different boost levels for different situations. can be set for different boost levels for each gear too. also can be mapped for different boost levels per rpm. also has a feature to compensate for boost drop off at high rpms.
its pretty tight. i got mine for $475 but they sell for around $525.
its also a boost/vac gauge too thats very accurate.
iceguyb14 is offline
Old 05-20-2009, 09:24 AM
sohc_mshue's Avatar
Actually the 500 is only $400.
sohc_mshue is offline
Old 05-20-2009, 10:08 AM
❒Good ❒ Better ✔Best
HighPSI TSi Guy's Avatar
hallman in car version, or HKS EVC EZ.
Those are the two boost controllers on the planet that work.
The rest are all miserable excuses. Unless you want to spend the big bucks on one like shue is talking about, they work pretty good too.
HighPSI TSi Guy is offline
Old 05-21-2009, 05:27 PM
suprarob's Avatar
suprarob suprarob suprarob suprarob suprarob suprarob suprarob suprarob suprarob suprarob suprarob
hallman are the best for sure
suprarob is offline
Jarrod
18
02-13-2009 07:58 PM
Quick Reply: Boost controller
