Cam gear question......
Old 04-06-2008, 04:01 PM
TRX 450 TYPE R
h23havoc's Avatar
h23havoc has disabled reputation
Default Cam gear question......
I had a d16z6 and bought a cam gear for it.Then decided to use a d16y8 instead and was wondering if they were the same.I know it will fit, but i was told that i had to set it on 4 degrees advanced for the timing to be right on the y8.Any help would be greatly appreciated.thanks in advance
h23havoc is offline
Old 04-06-2008, 04:12 PM
h22 POWA
gsr-turd's Avatar
gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd
Default Re: Cam gear question......
just put it on 0, and re do timing on the car to stock. and it shouldn't matter i would think. but i don't mess with to many single anymore so i can't say to be 100% on it.
but i would think if you have the cam gear on 0 and just re do timing on the car to stock spec it would be stock. not advanced or anything. but i get a second opion to safety on it.
gsr-turd is offline
Old 04-06-2008, 04:38 PM
TRX 450 TYPE R
h23havoc's Avatar
Yea thats what i thought too.But i was told the key is in a different spot on the y8 cam or something like that. thanks tho
h23havoc is offline
Old 04-06-2008, 04:43 PM
Ohhh Snap
madsteez's Avatar
madsteez madsteez madsteez madsteez madsteez madsteez madsteez madsteez madsteez madsteez madsteez
Yes you will be abou .5 of a tooth off.You need a stock d16z6 cam or aftermarket d16z6 cam.The y8 cam gear will throw your timing off. I believe you may also be able to use a d15b7 or d15b8 cam hear.
but YOU CAN NOT USE A STOCK Y8 CAM GEAR,AND IF YOU DO RUN A AFTERMARKET Y8 CAM GEAR MAKE SURE TO TO ADVANCE THE TIMING 4.75 DEGREE
HERES A PICTURE
Ignore the bottom end caption,thats my motor.
madsteez is offline
Old 04-06-2008, 04:48 PM
TRX 450 TYPE R
h23havoc's Avatar
thats what i thought,oh i have a completely stock y8 also.sold the z6 swap but still had the aftermarket cam gear so i was gonna use if i could.thanks alot
h23havoc is offline
TurboEG8
12-02-2008 02:34 PM
Slow93hbSi
02-10-2008 04:43 PM
vasponger
12-26-2003 08:31 AM
Quick Reply: Cam gear question......
