car broke down...
Slammedxpert
Re: car broke down...
Yeah, try a new main relay for sure. It's a simple fix, it'll cause the symptoms you had. The solder they used back in the day was cheap and it just comes apart easily.
okay... well, i walked the 1/2 mile to my car... rechecked fuses, grounds and tried a new main relay. the led on the ecu is still solid, and im not hearing the fuel pump prime.
could a faulty fuel pump cause the solid led on the ecu? that's whats puzzling me... i wanna get a hold of a pm6 or a pm7 and try another ecu...
EDIT:
im running through the events of last night up to the point where my car died...
-car started misfiring throughout the driving range\
-my o-meter was displaying afr all the way into the 18.5's... when the car was shuddering... (it's not just a light show... i actually have an lc-1)
-erratic idle from 500rpm up to 2000rpm
could a bad fuel pump cause this?
EDIT:
i swapped the engine from the a6 to a dohc zc over a year ago...
and yea, i definitely replaced the main relay haha... i've already resoldered one of them before... but i bought a spare just in case. i just swapped in the spare one...
could a faulty fuel pump cause this?
ok, i just checked the main relay... and that checks out...
but for some reason, im either getting 0v or 6.3v to the fuel pump. shouldn't it be gettign somewhere near battery voltage?
Digital Life
I dont think volts maintain to a fuel pump, they should go up and down depending on the resistance of fuel flow.
Like, once your fuel pressure is up, it shouldn't have to use a full 12V because the system is primed and for the most part, the fuel intake itself would pull from the forward part of the system. The pump gets the system primed, and keeps the fuel flowing forward under load.
Even if you had it wired straight to a 12V source(battery), it wouldn't use it the full 12V unless it was an unprimed system already under load(first start).
Those relays can be fixed by having someone reflow the solder joints internally. It's kind of a pain in the ass but it can be done by someone who knows what they're doing.
The reason for the change is that the wires have a resistance, and when you pass a current through a resistance, it causes a voltage drop. This is Ohm's Law, which can be basically stated as V=I*R, which is voltage (in this case voltage drop) = current x resistance. So in order for you to be getting 6.3V at the fuel pump while it is running, you either have to have a lot of resistance somewhere (maybe a corroded terminal or bad ground, etc., or the fuel pump is drawing a LOT of current. Basically, if you have 12V at the battery, and 6.3V at the pump, you have a voltage drop (somewhere) of 5.7 volts..
Given the age of the car, I would go for the high resistance theory and assume that there is a problem with the wiring or terminals somewhere, or in the fuel pump relay.
The pump will need a certain amount of current depending on the pressure and flow that it is pumping. Higher pressures make a higher load for the pump, so it draws more current. Higher current will mean higher voltage drop at the pump, because of wire and terminal resistance (see my above explanation). This is why larger wires are better for higher current, because their resistance is lower because of their larger cross sectional area. Less resistance means better current flow, so less voltage drop.
So to get the best power out of a motor, you want the most voltage that you have available, and the least resistance to current flow.
Fuel pumps are directly connected to the battery, and a fuse and a relay only add a very small amount of resistance into the circuit (just like the wire does).
Digital Life
Maybe I'm just having trouble explaining it in a way he can understand.
Breaking stuff down for people isn't easy for me.
I have been in school for computer electronics engineering, I know all that you said, I wasn't going into the detail you did though.
Assume I do know, then re-read my statement. Listen to Fabrik8 though, he deff knows his stuff
