Car idles up and down when first starting car help please.
Read over these links:
http://honda-tech.com/zerothread?id=699787
http://www.ef-honda.com/ben/Badidle.php
More than likely its the FIT valve...
CIVIC4LIFE
![93DX is an unknown quantity at this point](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
Ok i cleaned out the iacv and the throttal body and it is still doing the same thing. is there any thing elss?
I am changing the pcv next along with the upper hose that leads to the intk manifold the hose is caved ion a little so that is next.Is there any thing elss that could be wrong?
fabricated reality
![kawgomoo can only hope to improve](https://www.vadriven.com/forums/images/reputation/reputation_neg.gif)
yeah you completely missed the thermowax valve thing. its the valve under the t/b. its out of adjustment you fool! lol anyhow take the 2 screws off the end and use a big flat head to tighten the large white thing in the middle.
THIS IS NOT THE IACV.
CIVIC4LIFE
do i have to take it off the t/b or can i just leave it on. also when i unscrew it will coolent come out? also nother ? what would cause your car to like shut off and turne its self back on while driving, this has happend a couple of times and wunder ign what this was.
CIVIC4LIFE
any one also know where the middle were goes to on the map sensor plug
i check the valtage and it said that it was ssapoed to be at 5v but i only got 3.5. and every thing elss i ched out vaultage wise was straight
Ghost
Originally Posted by swtch7
wow
CIVIC4LIFE
opps sorry for the ****up on the not and what middle __________ hear is what i ment.
any one also know where the middle wire goes to the blue/red wire on the map sensor plug.
JAY SPEC
![00civichatch](https://www.vadriven.com/forums/images/reputation/reputation_neg.gif)
#2 its ok to cuss, we are all adults here.
#3 PLEASE READ AND CORRECT YOUR SPELLINGS ( i.e. "vaultage": VOLTAGE "ssapoed": supposed? ) again we are all adults here, we cannot help you if we cannot comprehend what you are trying to explain.
#4 welcome to dragva.com
