Car Shakes When Going Over 30. Anyone May Know Why??
![laserspeeddemon is infamous around these parts](https://www.vadriven.com/forums/images/reputation/reputation_neg.gif)
![laserspeeddemon is infamous around these parts](https://www.vadriven.com/forums/images/reputation/reputation_highneg.gif)
Take your car to an alingment shop. Have your car aligned and your wheels balanced. If the rim is bent, they will tell you. If they are not, then they will balance them. Putting on 3 sets of unbalanced problems wheels won't tell you the issue. They should check the condition of your ball joints, wheel bearings and tie-rod ends as well. They probably won't check your axles, but if they are not clicking then they should be fine.
my name is andy.
![Fiziks](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![Fiziks](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
Rotate your tires front to back and see if it moves to the rear if it were your axles they normally will vibrate on acceration and it will go away when you let off the accelerator that is typically the case on drive line dynamic vibe's.
