car will not go past 3 grand then wants to cut off
Old 10-07-2010, 10:29 AM
fastsohc's Avatar
fastsohc fastsohc fastsohc fastsohc fastsohc fastsohc fastsohc fastsohc fastsohc fastsohc fastsohc
Default Re: car will not go past 3 grand then wants to cut off
So that brings up another question: Can you rev the car over 3k RPM sitting still?
no the fuel cut out as soon as it get past 3k sitting still or moving
fastsohc is offline
Old 10-07-2010, 11:47 AM
fastsohc's Avatar
ok came home got the speedo pulg up and dose nothing sitting still or moving, you tap the gas and the car wants to cut off like there no fuel getting to the motor if i unplug the map sencer the car runs the same, thing it may need a new map sencer
fastsohc is offline
Old 10-08-2010, 09:12 PM
'00_GSR/R's Avatar
'00_GSR/R is a name known to all'00_GSR/R is a name known to all'00_GSR/R is a name known to all'00_GSR/R is a name known to all'00_GSR/R is a name known to all'00_GSR/R is a name known to all
It would be alot easier with a CEL.... Yes, if the car was in limp (safe) mode, there would be a CEL.
'00_GSR/R is offline
Old 10-09-2010, 04:09 AM
tre4s13's Avatar
tre4s13 has disabled reputation
might be a stupid question but....did you check to see if the hose to your map was connected on each side?
tre4s13 is offline
Old 10-09-2010, 09:49 AM
There isn't a hose. The MAP sensor mounts directly to the intake manifold.
Old 10-12-2010, 07:31 AM
fastsohc's Avatar
fixs it
it was a fuel problem
fastsohc is offline
Old 10-12-2010, 09:05 AM
Cool, glad to hear it's fixed.
cleanEK
08-29-2010 05:40 PM
TurboEGferio
12-28-2008 10:35 AM
vbspec
07-22-2008 04:34 PM
Scottyk6
01-02-2008 11:59 AM
xXThat GuyXx
01-01-2008 08:34 PM
Quick Reply: car will not go past 3 grand then wants to cut off
