Car will not turn over...
Re: Car will not turn over...
I hope you got your car running by now. If not I would first check your battery connection and if it's ok I would check the ignition switch. I found that with age the wires on the switch get hot and melt the solder were it connects to the switch. Just pull the lower wheel cover and follow the key switch and you'll see where it connects to a bunch of wires. Tug on these wires close to the switch and see if any of them are loose. While you're there use a test light and see if you get power to the switch. good luck
Keep an eye on everything, there is a reason that the fuse blew. The fuse might have just fatigued or something and finally failed, but if it happens again there is a problem somewhere.
