CAR WONT START.
Old 04-10-2007, 03:56 PM
  #31
Turbo VTEC-E
black6gen's Avatar
black6gen can only hope to improve
Cool Re: CAR WONT START.
Originally Posted by idriveahonda
Is your tune set up for the 450cc injectors, or is it just set up for the stockers and you have the 450's in?
If you are running 450cc injectors on the tune for stocks, the car probably won't start because it is too rich.
Could be?
Nope sorry. Basemap is set for 450's.
black6gen is offline
Old 04-10-2007, 06:08 PM
  #32
carlosp38's Avatar
carlosp38 is an unknown quantity at this point
Default Re: CAR WONT START.
check your timing on the cams and on the bottble of the block ... did you change your clock recently or change your timing belt? does the motor sound dead? if it does then its probly your timing...
carlosp38 is offline
Old 04-10-2007, 06:25 PM
  #33
Justa lil 6
Dang Yo's Avatar
Dang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the rough
are u running a resistor box with these injectors?
Dang Yo is offline
Old 04-10-2007, 06:28 PM
  #34
Turbo VTEC-E
black6gen's Avatar
Yup.
Old 04-11-2007, 09:42 AM
  #35
Wanna Taste??
TazZ99CiviC's Avatar
TazZ99CiviC is an unknown quantity at this point
if the spark is weak, then look into that. did I see that you are running MSD, or stock distributor? If running stock "dizzy" then there is an issue inside. Might be the ignitor, or Ignition Control Module. Worth checkin into.
TazZ99CiviC is offline
Old 04-11-2007, 01:33 PM
  #36
krazdracer's Avatar
krazdracer has disabled reputation
you didn't accidenty happen to hook the battery up backwards after you did the swap did you????????
krazdracer is offline
Old 04-11-2007, 02:30 PM
  #37
Turbo VTEC-E
black6gen's Avatar
Nope battery is right and i even tried a diferent battery today and still the same. I have about had it with this thing and im thinking about taking it some where.
Old 04-12-2007, 07:20 AM
  #38
Wanna Taste??
Once again...
gen4H22A
11-23-2008 05:22 PM
TYLERp
09-03-2008 10:52 AM
sive ick
12-22-2006 02:42 PM
jstabb1
09-12-2006 05:46 PM
HateV8s
02-21-2005 05:05 PM
Quick Reply: CAR WONT START.
