car wont start, please help
slowest member
Re: car wont start, please help
my truck did that started fine turned it off i went to try to start it but never would turn over my coil ignitor had a huge crack down the side
hey my da was giving me the same problem and it ended up being the distributor coil....i would get one from somebody that has one and switch it.....by the way its medina if mine fits You can try mine i dont know what motor you have now but i have one for a b18a1.
I drive real slow
double check your fuel pressure... when i did major work on the monte and put it all back together, it seemed as though i was getting fuel and i had the same symptoms as you... would turn over but wouldn't catch, it ended up being a lack of fuel.
go get yourself a 10 dollar can of starter fluid and spray it in the throttle body... it it's got a spark it'll start up on that, even if the timing is fucked up it'll do something... if it starts and runs for ~30 sec then dies it's def lack of fuel.
edit: also check corrosion on the battery... sounds like a dumb suggestion but you would be amazed. my brother in law's focus wouldn't start at all this weekend, i cleaned the terminals and it started right up.
well, i replaced the coil about 3 months ago, so its almost new, and its getting spark, i replaced the fuel filter did nothing, tomarrow i am going to double check my timing marks, try the wires and a few other things, oh and btw medina, its a b16a2 just to hold me over for now, i decided that im going to build a ls/vtec turbo
its getting fuel fine, i triple checked the timing, took the main pully off and noticed that the timing is off a notch, i think it might have jumped on me, gunna try that and see what happens
When i wired up my tach i didn't get the distributor rotor in right and i couldn't start. So check the distributor rotor, take it out and if it's all corroded go buy another one and a new cap, should be around 25 bucks.
representyoshit
