Cd player installation.
#21
Re: Cd player installation.
those are mazda color codes.... unless the truck has been rewired that should be whats in the dash....The color codes for the cd player are different. but the yellow wire from the cd player to the amp fuse should work fine.
#22
±RepLegion
I actually have a Tsunami power wire kit which has an allen bolt on the fuse housing that you tighten down on the power wire. I might stick a wire in there then connect it and see if that works.
Thanks for the colors. The wiring in my truck is all crazy so those colors only really match my cd player.
#23
GUIBO!?
I got this from www.the12volt.com, its a great site btw.
1990-93 Mazda B2000/B2200 Stereo Information
Constant 12V+ Blue/Red
Switched 12V+ Red/Black
Ground n/a
Illumination Blue/White
Dimmer n/a
Antenna Right Front
Front Speakers 4" Dash
Left Front (+) Blue/Red
Left Front (-) Blue/Yellow
Right Front (+) Blue
Right Front (-) Blue/White
Rear Speakers 4" Rear Corners
Left Rear (+) Blue/Red
Left Rear (-) Blue/Green
Right Rear (+) Blue/White
Right Rear (-) Blue/Green
Ground n/a
Dimmer n/a
Antenna Right Front
#24
