Cel Code problem?
Cel Code problem?
When I jump the connector the srs light blinks but the check engine light doesn't it just stays on? I don't know how to check which codes the ecu is throwing if the check engine light is not blinking? Any Ideas?
Re: Cel Code problem?
I appreciate the link but I've already seen it....If you read it you will see that I have done everything that thread has asked but I don't get the same results that are stated I was wondering if any of you guys could help..
is there a cel on when you dont jump the harness is not your not going to have no codes, if so might want to look for another ecu
friend of mine had a computer that would do that just pop on at random car ran perfect he got another ecu, changed nothing and it never came on again
