Check Engine Light?!!?
DESTROYS DONUTS !!
i dont think both o2 sensors in front will work either because one reads before it is filtered through the cat and one is programmed to read afterwards, but it might, so fuck it try it.........and dont even try to buy a cat from honda, it will run you at least 1100 bucks, i guarantee that.........
hey doug. i have my check engine light all the time on my rsx. But reseting the ecu helps me out. Hondata didnt remove the check engine light but it did make it where it didnt do anything. So i would go with hondata. that way i can also race you again and beat you. haha.
i gotta P.H.D
No Daluded i havent paid the 6 bux for PO.com! So if i do get a high flow cat, i will still need the simulator? I thought if i got the right cat it would stop the o2 sensor from throwing a code!
back in ther vvti
doug i have an idea for you but it requre you to buy another 02 sensor and its not guarenteed to work but its worth a shot tell me if you are willing to try it out.
edit: i forgot to put my idea in. anyway the idea is buying another 02 sensor basically taking the clip cutting it from the 02 sensor plug in the sensor wire and splice the wire into the 02 sensor before the cat. dont know if it'll work but its a pretty good idea i think.
i gotta P.H.D
yea i think i might buy a Random Technology cat! I believe it will not throw a code! I am gonna call them and see. But thank you Randy for the idea. I just want to do this right the first time instead of messing around with it and making it worse!
