check engine light still
Maybe try the MD forum? In almost all cases, VA>MD... but not necessarily the case when it comes to our "car" site
so i did the revisited bypass of the fluctuation sensor which involved splicing and depinning two wires out of ecu and no difference . same code so im going with that maybe its the dizzy thats bad and or connection issue . is it possible for the car to run half way decent in limp mode if its throwing a crank sensor code ? also while scanning for codes another one popped up it was for the knock sensor . i looked and some how it came unplugged . that seemed to make it run a lil better . jus cant wait for this thing to crack vtec ! well if yall have any ideas or info i appreciate it thanks
It didn't sound like the crank fluctuation sensor was part of the problem at all, but you most likely would have needed to bypass it sooner or later anyway depending on what ECU you were using.
![Exclamation](https://www.vadriven.com/forums/images/icons/icon4.gif)
checked all the connections with a multi meter and its lookin like i needs a dizzy ! and wow those things are expensive brand new . any places i can get one rebuilt or used that any one would suggest ?
OV-104
![Atlantis](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![Atlantis](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
bap geon......they wanted 223 and 199 if your military.. advance wants 438....FAWK tht
