Clunking sound from right front wheel area.
Old 07-29-2010, 07:58 AM
mmkay92's Avatar
mmkay92 is on a distinguished road
Default Re: Clunking sound from right front wheel area.
so wasnt the weights....wasnt the brake shield...have no idea what the hell is causing it
mmkay92 is offline
Old 07-29-2010, 05:55 PM
Str8EJ's Avatar
Str8EJ has disabled reputation
Did you get an alignment? Did they tighten the tie rod ends?
You need to put the car on jack stands, take the wheels off and proceed to check each and every bolt and bushing on both sides.
Fortunately, 5th gens are simple and this shouldn't take more than an hour for each side, including breaks for refreshments.
Str8EJ is offline
Old 08-16-2010, 05:20 PM
DOHCda's Avatar
DOHCda has disabled reputation
sway bar endlinks.....does it get worse going over bumps or stay the same no matter what the road surface. could be control arms bushings, ball joint. Jack the car up from the pinch weld, get the wheel off the ground, shake the wheel side to side and top to bottom. (hands at 3 and 9 then hands at 12 and 6) if you feel anything loose get someone to shake it while you look for any unusual movement.
DOHCda is offline
CivicRenModelX
11-04-2009 07:45 AM
Atlantis
07-22-2009 06:58 PM
pedro 2.0
05-08-2006 06:53 PM
16g-95gsx
12-08-2002 10:09 PM
Quick Reply: Clunking sound from right front wheel area.
