Clutch Stuck
Hellafunctional
![Garrett93](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![Garrett93](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
I can disconnect the slave cylinder, but what do you mean by actuate? I can wiggle the fork around, and if I pull the pin out, I can move it around.
Hellafunctional
Previously Odyssey
![Odysseus Prime](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![Odysseus Prime](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
I think he is saying to pull the fork to see if will move the bearing into the pressure plate. ( disengaging the clutch )
Hellafunctional
Well on the transmission, there is a hole to where you can see the fork and move it around if that makes sense. And I've tried pulling and pushing it with a breaker bar, and couldn't get anything.
Previously Odyssey
Odd question that I have not seen asked yet.
Are you 100% sure the clutch kit (clutch + pressure plate + throwout bearing) is for your engine??????
Just thinking out loud.
TreblicTunedFTW!!
![Subie2Honda](https://www.vadriven.com/forums/images/reputation/reputation_neg.gif)
THIS. Garrett, Im starting to wonder if the clutch kits you have been getting are correct. Im pretty positive, after looking at it as I have, and looking online, that the throwout bearing itself isnt retaining itself in the pressure plate. Once that throwout bearing is fully engaged, it is extremely difficult/impossible to remove it from the pressure plate without the aid of a tool. Either way, the pressure plate helps to provide some tension for the clutch itself, as the fork actually pulls the pressure plate away from the clutch disc(pull type). Next time your in town and I have a free moment, Ill come by and look at it again.
Hellafunctional
