Code 22 !!
Old 08-28-2006, 09:45 AM
VTEC
diggity dave's Avatar
diggity dave is on a distinguished road
Arrow Code 22 !!
i know code 22 is somethin like vtec oil pressure or somthin
its not oil pressure because when i reset the ecu then i turn the ignition on it shoots 22 without running the motor i checked wiring i just cant figure it out someone on here probobly can help its a p28 (92-95)ex si i also tested the vtec solenoid and its fine
diggity dave is offline
Old 08-28-2006, 04:07 PM
Sumospeed #O.G.
SlowLS's Avatar
Default Re: Code 22 !!
It's vtec oil pressure switch. The piece the solinoid mounts to. Has 2 wires coming out. Make sure the wires did not come disconnected. One goes to the ecu other is just grounded somewhere. Check the wire at the switch itself and at the ecu.
SlowLS is offline
slo_b18
02-04-2008 04:42 PM
MrZoggs
06-01-2006 04:39 AM
DeepFreeze
12-07-2005 12:21 PM
HORNY4ZORNY
02-11-2005 10:50 AM
crxnfx
04-25-2004 11:41 AM
Quick Reply: Code 22 !!
