coolant leak??
Old 07-17-2009, 01:46 PM
D'sBB6
D'sBB6's Avatar
D'sBB6 has disabled reputation
Default coolant leak??
I have a 00 prelude with a fast coolant leak under the car, that i cant see were is coming from because i dont have a jack right on hand. and my coolant gauge needle has fell all the way to the bottom. as soon as i pour coolant in, is leaking out underneath the car. the radiator hoses appear to be fine, no leaks. could someone tell me was the problem, or were it could possibly be leaking from? thanks
D'sBB6 is offline
Old 07-17-2009, 02:03 PM
kashimiru's Avatar
kashimiru kashimiru kashimiru kashimiru kashimiru kashimiru kashimiru kashimiru kashimiru kashimiru kashimiru
Default Re: coolant leak??
coulda cracked your radiator or someone could have left the drain plug loose, which eventually lead to it falling out...
kashimiru is offline
Old 07-17-2009, 02:08 PM
やくざに成りたい
atmdc's Avatar
atmdc has disabled reputation
also intake manifold hoses and heater hose
atmdc is offline
Old 07-17-2009, 03:09 PM
PAWESOME's Avatar
PAWESOME has disabled reputation
make sure the bolts on your intake manifold are tight and all hoses are fresh and tight. It is most likely somewhere on your intake mani if it's coming of motor. I know mine had that problem, one time it was a loos manifold, other time it was a cracked hose going from intake to the block. Check it out and let us know.
PAWESOME is offline
Old 07-18-2009, 01:12 PM
D'sBB6
D'sBB6's Avatar
i can see were is leaking from now. i think is the drain plug loose on the back of the block, that has got loose somehow. because when i take off, or unscrew my radiator cap then it leaks out faster. since is about all out of fluid, it slows down or stops leaking out however much coolant is left. were do i tighten the drain plug at?
D'sBB6 is offline
Old 07-18-2009, 03:31 PM
D'sBB6
D'sBB6's Avatar
problem solved
D'sBB6 is offline
00_VIP_BENZ
06-29-2008 02:01 PM
quizzkidd09
03-06-2008 04:58 PM
91fastback
02-21-2007 09:31 AM
Cell
11-24-2005 12:20 AM
tiki240
09-23-2004 08:51 AM
Quick Reply: coolant leak??
