Corrosion on wiring?
Old 12-27-2006 | 02:23 PM
Mongoose87's Avatar
Slow ass car
Mongoose87 has disabled reputation
Default Corrosion on wiring?
So there is some corrosion on my battery terminal and also corrosion on the fuel pump relay. It is causing the relay to not work and the car will cut off. Any idears? It's an 03 Mazda 6
Old 12-27-2006 | 03:10 PM
Ross's Avatar
Ross is an unknown quantity at this point
Default Re: Corrosion on wiring?
For the relay I would recomend cleaning it with an electrical contact cleaner and usinge some white lithium grease on the conector. As for the battery I would recomend using a wires brush and cleaning the terminals the use some anti corrosion pads and possably a spray.
Old 12-27-2006 | 04:45 PM
boosted crx-R's Avatar
boosted crx-R is an unknown quantity at this point
CLEAN IT OFF!!
Old 12-27-2006 | 05:53 PM
kaltares's Avatar
CustomGSR
kaltares is an unknown quantity at this point
Originally Posted by boosted crx-R
CLEAN IT OFF!!
+1
Old 12-27-2006 | 10:05 PM
Scotch Brite works great for that, don't get the stuff that's meant for cleaning dishes though because it often comes with soap on it. Lithium grease is a good idea, but use it sparingly. Also check the connections that mate with the relay and inspect for corrosion. I understand the battery corrosion, but why is your fuel pump relay corroded? Is Mazda stupid and not using sealed relay connection systems like the big boys?
Blaznkwest
02-23-2009 03:11 PM
USElesRyDeR01
08-30-2005 11:20 AM
TPJ
05-13-2004 08:17 AM
Quick Reply: Corrosion on wiring?
