crx mini me help
Old 04-11-2006, 05:22 AM
DOHC crx VTEC's Avatar
DOHC crx VTEC is an unknown quantity at this point
Default Re: crx mini me help
Originally Posted by CHAHONDA
lord...the easiest way to get around all of this crap would be to use a y8 head and then the stock distributor would work fine. id get a y8 manifold as well. the y8 heads also increase compression slightly.
EWWWW Y8 manifold has doodoo pickup. if your staying OBD-0.......Keep the CRX SI intake manifold....Ive had this setup before...
DOHC crx VTEC is offline
Old 04-11-2006, 11:58 AM
crxgsr2004's Avatar
crxgsr2004 has disabled reputation
well i have a crank angle engine code what the heck is that and how do i fix it ??
crxgsr2004 is offline
Old 04-11-2006, 12:03 PM
More then likely wired something wrong....gimme a sec
Old 04-11-2006, 12:08 PM
crxgsr2004's Avatar
ok where the ecu is its a mess
Old 04-11-2006, 04:43 PM
Hmm check all your plugs, Like see if anyof the wires "broke apart" from when it was converted. I had it happen once...could be a mis-wired distributor wire.
Old 04-11-2006, 08:22 PM
crxgsr2004's Avatar
ok
Old 04-12-2006, 07:00 PM
yuuu..oooo
norfolksfinest's Avatar
norfolksfinest has disabled reputation
yeah check the wiring cause that sh*t did look a little sloppy, i have an si intake manifold if you need it, i think you saw it when you picked up the car
norfolksfinest is offline
customhonda
05-30-2008 04:41 AM
TYPE JDM
08-10-2007 10:01 AM
Quick Reply: crx mini me help
