d15b clutch questions
![jdmchef](https://www.vadriven.com/forums/images/reputation/reputation_neg.gif)
ok so the motor was swapped and it has an aftermarket stage one clutch but not sure of the brand but it has yellow springs. but when i let off the clutch in first gear there is a squeak. almost sounds like the clutch is slipping but not sure. if i get on the car and shift into to second it doesnt slip though. so i geuss what i am asking is it the clutch slipping or is it something else. and if it is does any one know of any websites were i can get a clutch and flywheel kit.( keep in mind the tranny doesnt have the lower three bolts due to the dumb ass who swapped the motor in the car, and if any one has any bolts id appreciate it if they would sell them or tell me were i could get them. it also does it when car is warm or at a cold temp. any ifo appreciated
![backtoarms](https://www.vadriven.com/forums/images/reputation/reputation_neg.gif)
![backtoarms](https://www.vadriven.com/forums/images/reputation/reputation_highneg.gif)
I would DEFINITELY get those three bolts. And hope to God he put the dowel pins back in where the transmission meets the block. Makes you wonder how many other bolts he left out.
Well the pins were put back in the block and i also had the tranny swapped out from the original i just need the three bolt. Do you know were i can pick them up at
did it end up going bad??? what ended up being the problem? but yeah im in need of some bolts its at the bottom were the metal shield bolts up.
You could probably either go to any junkyard and pull them out, or take another one out of the tranny and match it up at autozone or home depot or something. But, I'd suggest going to a junkyard being that they're not all the same size in the tranny. Same thread pitch, but different lengths.
well im pretty sure its the clutch going out. well it doesnt slip to drive just lets out at the top and it sqeaks. any input. its also a hydro tranny
