distributer oil leak!
Old 11-10-2011, 09:17 PM
matthull10's Avatar
matthull10 has disabled reputation
Default distributer oil leak!
I have a 94' honda prelude si with a severe oil leak from the bottom bolt on the distibuter, I work at a tire/lube shop and some of the guys there said its just the o ring. But is it better to just replace the whole thing?
matthull10 is offline
Old 11-10-2011, 09:21 PM
Dillweed's Avatar
Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed
Default Re: distributer oil leak!
Oh man that motor is fucked
Dillweed is offline
Old 11-11-2011, 03:39 AM
VaDriven Mayhem
Lord Humongous's Avatar
Yep.
You're probably going to have to replace the oil pump and pan too. And since the oil is coming out the bottom of the distributor, you'll need a new one of those plus you'll have to check the heads since they probably haven't gotten enough either and they're fucked.
Lord Humongous is offline
wright's Avatar
http://www.hondaautomotiveparts.com/...UTOR+%28TEC%29
You can replace the entire distributor or just by the O ring that is causing the issue. If you have the money to waste it is up to you.
wright is offline
Old 11-11-2011, 06:15 AM
ITSBOCK
Eghatch93's Avatar
Eghatch93 has disabled reputation
http://www.bap-geon.com/
distributor o ring is a couple dollars that'll fix your problem no need to spend 100+
Eghatch93 is offline
dodo94integra
08-31-2006 08:50 PM
tie fitr
04-13-2006 07:36 AM
sebassttiann
12-12-2005 10:53 AM
94_CRVtec
08-24-2005 02:32 PM
Quick Reply: distributer oil leak!
