DSM problems!!! HELP PLEASE!
The Pro to call.
Re: DSM problems!!! HELP PLEASE!
christ.....
check for spark. check for NOID(injector pulse). check fuel pressure (with a fucking gauge). check compression. check mechanical time.
timing belt is my bet.
LTDTEAM.COM
when i was driving and the car died, nothing unusual happended. the dealer said it was the computer but like i said i'm almost 100% sure its not.
Check you IAC or MAF sensors if not check your fuel injectors and your intake filter. check your fuses also. i had a similar problem with my 2G they replaced my ECU but it didnt fix it it ended up being the Mass Air Flow sensor. is it auto or manual. Cause if its auto ill prolly know whats wrong with it my auto had every problem a eclipse can have.
LTDTEAM.COM
LTDTEAM.COM
ok guys. heres the deal. i checked the maf and coil pack yesterday and no luck. i'm getting spark on all 4 cylinders. my car gets fuel ( checked by unhooking top of fuel filter line). so now i'm out of fucking ideas. is there anyone out there that will let me use their ecu(one they know works) to test it out on my car? please let me know.
-mike
-mike
