E-cut out/ hesitant under boost
Old 12-30-2009, 11:29 AM
  #31
Slammedxpert
SortaFlush's Avatar
Default Re: E-cut out/ hesitant under boost
Serious about what?
I clearly stated to him and I'm sure I posted it, that the boost was probably spiking due to no restrictions now. I just didn't think to hard that just opening the exhaust, AFTER the turbo would make it spike 6+psi.
SortaFlush is offline
Old 12-30-2009, 01:09 PM
  #32
Get retuned with the cutout open. If you're using an OBD1 ECU, there are easy ways to use a map switch so that you can have a completely different tune with the flip of a switch. That's not necessarily something that you want to do on the fly though, unless the programs are absolutely identical except for the map values. Basically you use a chip that is twice as large as normal, with two complete programs in it. Then you toggle one of the address lines, and you read out of the first half of the chip memory instead of the second half, etc.
f-av8
08-30-2009 06:56 PM
JDM_EF-9
09-14-2008 10:55 AM
ravenracer
11-17-2007 08:54 AM
Wickedy Wick
05-27-2005 11:23 AM
Quick Reply: E-cut out/ hesitant under boost
