ECU code problem
ECU code problem
my ls swap is throwing the "cyp" code.I looked it up and all it says is a bad sensor,but it dont say which one.I need to figure this out,any suggestions?
Digital Life
Re: ECU code problem
CYP Sensor (Cylinder)
defective circuit or unplugged / defective sensor
Check it out. If its ok, check your timing, and make sure you dont have your air intake sensor and IACV mixed up.
It could be the wiring too, don't assume the sensor is bad yet. With an engine swap I always assume it's the wiring first and troubleshoot from there. You'd do that too if you'd see the swap wiring atrocity that I've seen.
CYP is cylinder 1 position sensor if I remember correctly.
