Eg with teg suspension axle problems. HELP
Boost is Better
Re: Eg with teg suspension axle problems. HELP
You can use either the DA or the DC axles. The only difference is the driver's side intermediate shaft. The DA uses a female halfshaft with a male axle, the DC has a male halfshaft with a female axle.
If your axle looks stretched and keeps popping out its def not a DA or DC passenger side axle.
This is what I thought which is why I put a DA axle in since I had it but it seems short and I know for a fact that it's from a 92 integra (DA correct??). If this is the case maybe I have something majorly wrong with this setup. The drivers side axle is perfect and I never have any issues with it and it looks fine so should I try a DC axle and hope that will fix it?
Boost is Better
All Motor All Day
I have heard that some remanufactured axles (from autozone etc), end up being too short. Idk if thats the problem in your case. However, if you do have a dc axle laying around I would try it.
Boost is Better
I don't have a DC axle just lying around but I do have a friend that works at advance so I will just purchase one tomorrow and throw it in and if it doesn't work I will have to go a different route
