eg vtec rough idle, excessive fuel consumption, and hesitation while cruising.
![91slomatic has disabled reputation](https://www.vadriven.com/forums/images/reputation/reputation_off.gif)
I have a 95 civic ex with the d16z6 motor. The other day it started idle rough and consuming more fuel. Also while cruising at a steady speed the car would hesitate till I went full throttle. Map sensor and tps checked out fine. However I have codes 21 - vtech spool solenoid. 22- vtech pressure valve. And 43- fuel supply system. 21 and 22 were past codes due to a wiring problem long ago I fixed. But the 43 has me stumped. Im thinking a new fuel filter and check the vacuum lines? Any info on any possible fixes is greatly appreciated. Thanks!
MARK IT ZERO
![ufctapout](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![ufctapout](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
MARK IT ZERO
MARK IT ZERO
Shooting 63's
![idriveahonda](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![idriveahonda](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
