f22 vs h22
BNB MOTORWORX
Re: f22 vs h22
ok first ill say welcome noticing that you just joined last month as for your question what are you askin cause your thread title says f22 but your talking about a f23 what i can definitly tell you is the bore and stroke is different. the f22 has 85mm bore f23 86mm and h22 has 87mm. im an accord guy so ive delt with alot of f series. im sure more people are gonna say it ill just be the first, the best thing i can tell you is search just google your question or check out hondaswap.com and honda-tech.com. If you get stuck and need it explained pm me and ill help
gotta go gotta go
Re: f22 vs h22
Yes and no. H22 internals "can" go in but there are things you gotta consider. First off, you'll definitely need to bore that F23 out to 87mm in order to make the h22 pistons fit. Secondly, the f23 has a 97mm crank, meaning the longer h22 rods will push the pistons out of hole (by a whole lot). Easy way to remedy that is take the crank of a h22a4 ('99 and up preludes only) and drop it in the f23 block. You can't use pre-'99 cranks because of the differences in size of the mains (h22a4's of '99 and later share the f23's 55mm mains). Essentially, you're destroking your motor into an h22 but with a little higher compression. Never seen it done so I don't know how that would turn out as far as putting power down. If I had the parts already lined up, then I would go with higher compression pistons(Type-S maybe or better). Or, I wouldn't overbore the block (keep the f23 pistons for low compression) and just boost the living sh** outta a rev happy motor that has OEM iron sleeves! I have seen the build the other way around (H22a4 with f23a1 crank and rods w/h22 pistons) and it produced one monster ass build. Good luck.
Re: f22 vs h22
gotta go gotta go
Re: f22 vs h22
Well, if the benefit of the f23 block is that it has iron sleeves, and a pretty decent size stroke. The down side is the rod/stroke ratio (1.4x). The upside to H22 internals is it's ability to rev higher because the r/s ratio becomes 1.58. The stock compression of a f23 is about 9.3:1. With a stock h22 it's about 9.9 or 10:1. A f23 with h22 crank, pistons (have to overbore) and rods would have a higher compression (about 10.5:1) than a stock h22 and keep the r/s of 1.58. With that much compression, you'd want to get that f23 head to flow better to really take advantage of that extra potential power. If you're boosting, you could find low compression pistons for the h22 and alter the compression. A f23 with h22 crank, rods and f23 pistons (don't have to overbore) would yield a CR of about 8.1:1 and keep the r/s of 1.58. BUT, the piston will be out of hole some, I can't remember how much. So really, it's about budget and how much work you want to put into it. You're right, there isn't that much support for the f23 but I have seen some out there. If I find them, I'll post.
