fuel pumps
Base 1G FP is 37.5, under boost you need 1 more PSI of fuel for every 1 PSI of boost. If you have a 1G you should be OK without a FPR. I have one on my car but soooo many I have talked to don't run one. Get the HP pump, you won't regret it. -Ian
Get the high pressure walboro. i ust got mine in yesterday and put it on tonight, made a huge difference. also dsmparts.com was the cheapest i found as far as price goes. you can only hear it running if you are siting still with out the radio on, so its pretty quite.
Administrator
Originally posted by 385LT1
Or you could get the "Lake Dewatering Device"
What's up with the gigantic pictures? Resize is your friend ~_~
__________________
Got a 1995-1996 240SX? Want a new front bumper?
Check this out. Posting on drag first to try and avoid shipping it.
Administrator
I didn't say there was anything wrong with it. I'd do that too if it were my car. AN fittings are the hotness, they're just really really expensive
I'd venture to guess that for most peoples cars a Walbro would be more than fine.
__________________
if it helps, I have a Holley 255 in-tank in my car right now....
I will know how well it works after i air/fuel it and monitor the injector duty cycles.... If it works well..... Its staying in there for awhile.....
