Gas smell and engine still wont turn over.
#21
Don't listen to the fuel map comment. He was trolling. And having the distributor timing should not affect the car starting. All the distributor timing does is retard or advance spark.
#22
![zrts2008 has disabled reputation](https://www.vadriven.com/forums/images/reputation/reputation_off.gif)
well it might be too retarded and getting it to not spark high enough even though its dead center.
so what all do you think i should do?
#24
well in that case if i put it in TDC, itll start? i did that earlier and it didnt go into run. it cranks but ill give it a shot....
#25
If it still doesn't crank after, advance the timing on the distributor. Try to push start the car as well. If it starts that way and stays running, its a ground that's bad somewhere. Are you getting a CEL?
#26
11B3P
![Airborne29th](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![Airborne29th](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
Check and ensure you have all your grounds reconnected, one to the Head, one to the Tranny and one to the Thermostat... shouldn't be any others but I may be mistaken.. I've been there before with a loose ground on the Thermostat and had same symptoms..
#27
where is the ground on the thermostat? because i put a new one in but i didnt touch any of the wires on it.
#28
Make absolutely sure that the plug wires are in the correct order. I know that sounds obvious, but I've seen many people put the plugs wires back on in the wrong sequence. I've done it once or twice when I wasn't paying attention, but found it when I went back and checked. I'm not a big fan of things that can be assembled in multiple configurations, because sooner or later you're going to accidentally do it wrong.
#29
#30
11B3P
[ATTACH=CONFIG]139120[/ATTACH]
