GSR swap wont start
#21
Originally posted by 1slowCRX
If it is backfiring through the intake it is because the timing is off, your intake cam is advanced. If you think about it, it is firing right, but it is firing when the intake lobe is open causing the "explosion" to come out of the intake manifold. Try resetting your mechanical timing, and remember to route so that you leave all the slack on the tensioner pulley.
#22
It could be retarded also but it would have to be set back pretty far.........i would start by just putting the cams at TDOC of # 1 then put you crank at TDOC of #1.....it shoud have like a little mark on the crank pulley and that will line up with an arrow on the block, it is prob ont he right hand side of the pulley like upper left area, then just run you timing belt, tensionser side LAST and you should be able to fire it right up if evrything else is ok. Time it with a light after to set our ignition timing.
#24
Originally posted by 91 Hatch
did you check and make sure your spark plug wires are in the right firing order if they are and its still doing it your timing is off......my friends car did the same thing and his plug wires were in the wrong order..
#27
i checked inside the dist. when everything was set at TDC. The metal thing on the rotor is pointing towards the upper left spark plug, which I believe goes to cylinder #3. Should it be pointing to the lower left, #1?
