GSR Tranny problem
Re: GSR Tranny problem
craig just drain the fliud from the tranny and check for metal shavings ig the diff or the spider gears going from the diff to teh main dive are shot you will have some metal flakes or shavings in there cause trhe metal magnet in the tranny will not catch it all so drain the fluid
dude r u serious....
the c lip on the end of your axle is not working....
try pushing it in a lil harder...
if your axle pops out, your diff is gonna burn up if you keep trying to drive it... esp reving it up and putting it in third gear.... get that axle back in right and it should drive.
Like I said and everyone else. You are wasting your time and money if you do all that. I will put money on its the little clip on the end of the axle not in all the way
