h22 help
Old 03-03-2010, 02:46 PM
tits anyone?
I Love (.)(.)'s Avatar
I Love (.)(.) I Love (.)(.) I Love (.)(.) I Love (.)(.) I Love (.)(.) I Love (.)(.) I Love (.)(.) I Love (.)(.) I Love (.)(.) I Love (.)(.) I Love (.)(.)
Default Re: h22 help
as far as a stout all motor build on an h22, id go with a sleeved block (GE, AEBS, darton), some je or similar pistons, acl or kings bearings, eagle or scat rods, micropolish the crank and have it all balanced. thats a strong bottom end build imo. as for the head, aem cam gears, skunk2 stage 2 all motor cams, skunk2 valve train, and injector choice is you call as well as the CR piston you want. make sure you get a good header and an even better tune. with that build, you could have a beast turbo motor, nitrous motor, or just n/a. it will depend on the CR and cam choice. and when you are trying t get as much power as possible you can always go with a bigger bore on the sleeves and start porting and polishing.
I Love (.)(.) is offline
Old 03-04-2010, 08:05 AM
Full Access Member
egsir's Avatar
egsir egsir egsir egsir egsir egsir
id'd put stock jdm type s pistons w/ skunk 2 vaulves n spring& retainers and some stage 2 cams . Thats another option
egsir is offline
Old 03-04-2010, 09:06 AM
lil_nino187's Avatar
lil_nino187 has disabled reputation
As far as putting aftermarket
Internals. Should I do any machine work to head or block
Work.
lil_nino187 is offline
Old 03-04-2010, 11:42 AM
sleepinEG's Avatar
sleepinEG has disabled reputation
depends if your gonna bore it out or not,and regardless you need to get the blocked honed before building it.
sleepinEG is offline
streetbeat911
Engine / Exhaust / Drivetrain
01-26-2010 04:53 PM
TNGChris
02-05-2008 03:50 PM
sloaccord
12-17-2006 08:21 PM
Quick Reply: h22 help
