h23/22 del sol
turbo on 2 wheels
Re: h23/22 del sol
i got everything hooked up now, but the only problem now is its throwing a vtec spool solinoid CEL, is this because it used to be vtec and now i have an h23 non vtec?
Re: h23/22 del sol
try to use the h23 ecu (non vtec) i did a h23 swap in one of my si sols, used the h23 ecu and had no engine lights..... if u dont have one i might have one still..
turbo on 2 wheels
Re: h23/22 del sol
i have another problem now!!! i cant get the car to start with the key! when i turn the key nothing happens, no clicking, nothing, but i can jump the starter and it starts up and runs fine.... i have checked all my ignition wires and fuses and they are fine! HELP!!!!
Re: h23/22 del sol
Ground wire on starter?
turbo on 2 wheels
Re: h23/22 del sol
its there and good conection too, i can jump the starter like with a wire and it starts up fine, so the starter is good to go!
Re: h23/22 del sol
sound like ur ignition sw is going bad.. or ur clutch sw isnt closing.. bypass ur clutch sw first and then try.... if no luck try turning the ignition off and on repeatedly a few times and if no luck then it sounds like the ign sw... good luck
