Head gasket failure
I have a 20 valve...
Re: Head gasket failure
I have had a valve gasket pop on a mercedes, a honda and chevy. it comes from improper fit, high temps or over pressure. its an easy fix.
your fucking brain isn't.
Function > Form
God damn you are fucking stupid. ever single post you have ever made in tech talk has been filled with ludicrous bullshit. because you are 16, you've never seen a lot of shit. so shut the fuck up.
I suppose I'm just going to put on a new gasket and see what happens??
Thanks for all the help guys.
Fabrik8 - you have repz
Function > Form
Fidel runs VBPD
valve cover gasket leaking oil into spark plug hole, oil caused short in wires, thus car doesn't run... quit drinking so much and you might be able to have a running car.
Function > Form
Va Beach Coast Rider
Exactly the issue (except that it might only be the plugs).
Just spend the 10-30 bones for a complete valve cover gasket kit and replace it; it will take you minutes. Check the plugs as oil leaking is the reason it won't turn over. You might not even have to replace them (or the wires); just clean the plugs. As long as it hasn't been leaking for a while and there is no damage to the wires and/or lifters (because of loss of oil while running) you should be fine.
Function > Form
Fidel runs VBPD
Function > Form
1) Blew my knee out
2) Prob lost my job because of it
3) Car doesn't start
Excuse me if I don't always joke back
