HELP ASAP PLEASE FUEL PUMP NOT CUTTING ON!!!
![1slowEG has disabled reputation](https://www.vadriven.com/forums/images/reputation/reputation_off.gif)
ok got a different main relay but it is still just clicking and no fuel pump only way i can start it is to hot wire pump...HELP WEEKENDS ALMOST OVER AND I GOT WORK MONDAY
if you can't figure out anything else just hotwire the fuel pump to a fuse that cuts on and off with the key. then atleast you can go back and forth to work
ok guys figured it out!!! my yellow/green pump wire was bad i had NO conuity going thru so it had a short some where so basically i just had to replace that wire and it works just like new now!!!!
