help me decide what to do!
Re: help me decide what to do!
hey brandon, I think you should get a cheap block and build it with strong pistons and rods, find a decent head with low miles and boost around 10-15psi. It would be as much as buying the motor and having them put it in. Only difference is you have twice the horse's. Im in the middle of my first swap and its nothing big, thats why its a honda. I can understand if you live in an apartment and cant do it there or you dont have any friends that will lend you a driveway for a day or two. But seriously either go bigger motor or build a d15 and boost the hell out of it.
sumospeedDOTcom
dont even waste your money building a d15. why build a motor thats going to make as much or less than a b series would stock? lets say you put 2gs into a building a d15, boost it, and make 230whp, not bad. or you can just get a STOCK b series for the same money, boost that, and make the same power, more torque, and still have much more room for improvement. a.k.a. the bottom end is still stock.
Bitches get Stitches
b16. i can go on for so long about how inferior the SOHC's were built as opposed to the DOHC honda motors. the obd0 b16's are incredibly cheap and with a few very key mods (lightweight flywheel,clutch, header, exhaust) it will be very quick for the amount of money you spend on it.
oh yeah also wiring in VTEC is only one wire. use the pr3 ecu and there really will not be much to it.
honestly... the d15b7 swap is whack. it pulls harder than the stock motor, but itll get walked on by anything else. i had a 1.6L sohc d16y7 just as a replacement motor and I walked on d15b's all day. its honestly not worth the money. if you have the money to pay tuners edge to do the swap, then you should easily have the money for an LS swap, you can usually find one for less than 1000 without a problem. then just get a couple friends together to do the swap, its quite simple.
the d15b comes form the civics vti in japan....and its got vtec....*woohoo* how much will it cost to do all this liek i have stated above??? tuners edge to put it in, get motor shipped to them, wire vtec, and convert from obd0, and put a camber kit on, and tune a lil bit so its perfect....i think ima run a chipped p28 or somethign....not decided on the ECU yet or the specs for it either...but this is all goign down in about 1 week, so any tips/pointers/advice/would be great....but i gettin the D15b swap, so no more motor choices or ne thign jsut what i should do to it..
and alos i have a question....this car (the 90 dx hatch) i drove it yesterday, and the power is almost non-existant, he said the cat was clooged...liek i was in first gear and i was flooring it, and i swear to god it took about 10 seconds for me to hit the shift lite....??? is this the cat/resonator clogged up liek he says???
let me know thankx
Originally Posted by dorko
its not a d15b7 swap....its the JDM d15b swap...d15b7 motors come here in the civic dx's and shit...
the d15b comes form the civics xsi in japan....and how much will it cost to do all this liek i have stated above??? tuners edge to put it in, get motor shipped to them, wire vtec, and convert from obd0, and put a camber kit on, and tune a lil bit so its perfect....i think ima run a chipped p28 or somethign....not decided on the ECU yet or the specs for it either...but this is all goign down in about 1 week, so any tips/pointers/advice/would be great....but i gettin the D15b swap, so no more motor choices or ne thign jsut what i should do to it..
let me know thankx
let me know thankx
yea i gettin full exhaust, undecided on the cam to get...(whats the best on efor the d15b)....cam gear....plugs, wires, intake, jsut the basic lil stuff that adds make 15 HP max...you know....
but im sellign my car to him, and getttin his 90 hatch, and then i have 4800$ to play with ....so im gettin the motor, exhaust, rims, tires, paint job (undecided), cam, gear, clutch is brand new (stock)...ima wait till this one gives out, until i get a new stage 1 ish clutch, and im also gettin the tranny for Hmotorsonline too....unless the gears in the dx are better than that tranny?? not sure...its only 150$$$
