help please
i have a 1993 hatch vx my tail lights and dash lights are not working,my headlights work, i checked all fuses and there all good is ther a relay somewhere i should check,
![bLu92bUbbLe has disabled reputation](https://www.vadriven.com/forums/images/reputation/reputation_off.gif)
this just happened 2 me last week...all my fuses were fine 2....i just put the fuse in the wrong spot when i was checking them....make sure ur parking light fuse is in the rite spot..,..
mine did the same thing and it was the combination switch. when u turn ur lights on(at night so u can c ur dash lights) slowly twist the switch back towards the off position and ur dash lights should come on or at least flicker a bit. if so u know its ur combo sw... good luck.
![Drink](https://www.vadriven.com/forums/images/smilies/beer.gif)
Turbo VTEC-E
![black6gen can only hope to improve](https://www.vadriven.com/forums/images/reputation/reputation_neg.gif)
![Cool](https://www.vadriven.com/forums/images/icons/icon6.gif)
Are you talking about the lights when you hit your brakes or the running lights in the tails? If it is the running lights that aren't working, that would make sense seeing how the dash lights and running lights are in the same circuit. Check out your wireing diagram in a hanes manual and look for possible points there could be a ground or short, shuch as a pinched wire where something was removed and reinstalled.
