high idle....help on fixing it..
Originally Posted by civic1987
well his car 1st idled high in the cold, so we didnt think about it too much, but then it got warmer and it never really slowed down, i mean it would idle about 500 less but still take awhile to drop down,i mean i knoe that the wiring is wrong like u said above but wat would be wrong???.........let us know so we can solve this bs problem
![1qikcoupe has disabled reputation](https://www.vadriven.com/forums/images/reputation/reputation_off.gif)
Originally Posted by JDMS1eeper
does it surge? how high does it idle?
Sumospeed #O.G.
![SlowLS is an unknown quantity at this point](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
Thry the link I posted in this thread http://www.dragva.com/forums/showthread.php?t=114754
(just a theory) my cb7 does this
when you start your car it will idle high (1.5-2.0 rpms) to warm it up somewhat faster... some cars do that atleast...usually when the engine is warm enough then the idle will settle (.5-.8 rpms)
correct me if im wrong
Sumospeed #O.G.
Yes, your car should idle higher while warming up, with is what the FITV controls. However a common problem on older hondas, is a really high idle during warm-up (like 3k) and once warmed up will drop between 1.5-2k.
its either a problem with the iac motor or throttle position or cam or crank sensor.figure out what pins the sensors r on the pcm. check the wire on the pcm pins to the sensors to make sure its not a wiring problem and check ohm readings on the sensors to make sure they r not bad. find somebody for where to find information on pin position and the read sensor values. im a gm tech thats as far as i can can go.
bolivianfuego
07-25-2008 10:39 AM
