High Power D16z6
#22
Re: High Power D16z6
lol at port and polish the engine. if you want a high power d, you need to sleeve the block, get some vitara low comp pistons, eagle rods, balance the bottom end, port and polish the head, a good turbo cam, adjustable cam gear, vavles, springs and retainers, some big injectors, and a bigger fuel pump. I think you need to do some more searching and get a little more knowledge before you start building a motor.
#24
with 250-300whp you will not have a beast by any means or even a fast car. your car will just be quick to some people. it's 2010 bro if you aint shooting for 400+ you aint doing much. people are making 250- 300 all day on the stock bottom end all the time now days. all you need is a decent size turbo, vitara's, eagles or fjt i beams rods, arp headstuds, bisi 2.4 cam, valve springs, and a good tuner. o and possibly a water/meth kit if you want to be really safe without using race gas for higher boost
#25
Complete Vitara bottom end kit right here http://fjdistributors.com/product_in...roducts_id=564 or you can just get the Vitara piston's and I Beam rods by themselves.
But please do some research. You sound like you don't know what you're doing.
#27
#28
Dickbutt #peentip
#29
#30
Here's a simple one that could inform us of your knowledge or lack there of.
Which afr (air fuel ratio) is leaner(less fuel) 13 or 8?
edit: If that's too hard, then answer this. Where does your muffler bearing go?
