hks bov issue
Old 12-11-2008, 10:54 PM
Default Re: hks bov issue
So you're saying you've installed another one and it doesn't work either? Did something happen with the intake piping that may have warped or twisted the mounting seat such that the BOV is getting deformed? Have you checked for blockage in the vac line?
Old 12-12-2008, 05:27 AM
FL1PSDE 101
Fl1pSde 101's Avatar
Fl1pSde 101 has a reputation beyond reputeFl1pSde 101 has a reputation beyond reputeFl1pSde 101 has a reputation beyond reputeFl1pSde 101 has a reputation beyond reputeFl1pSde 101 has a reputation beyond reputeFl1pSde 101 has a reputation beyond reputeFl1pSde 101 has a reputation beyond reputeFl1pSde 101 has a reputation beyond reputeFl1pSde 101 has a reputation beyond reputeFl1pSde 101 has a reputation beyond reputeFl1pSde 101 has a reputation beyond repute
yeah i installed another one and still didnt open up.....like I picked it up from stock or modified when it was worked on came home it was working fine 3 days later for some reason it just stopped opening up.I replaced the vacuum line,tried other vacuum source on its own..stil no luck.I tried to push it with my finger and its real stiff and had to put a little force to push the piston back.before my bov opens up a lil on idle.now its just completely shut.im not sure if the vacuum is not storng enough or someone on here suggest taken one of the springs out to loosen it up and it should work but im not sure about it cause i had my old one for over a year and worked fine..u think there a vauum leak somewhere,could dat be a possibility
Fl1pSde 101 is offline
Old 12-12-2008, 05:39 PM
brandon.beene's Avatar
brandon.beene can only hope to improve
do like i said and let me know what happens
brandon.beene is offline
