honda swap ?
![dohcEG is an unknown quantity at this point](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
what exactly do you mean? just change the ecu. if so what about all of the wiring, i dont think it plugs in. what wire harness would you use, the 88 or the 92?
Registered Offender
![Mr. Rooney is an unknown quantity at this point](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
most wiring harnesses are the same. the only "wiring" you'll need to do id vtec and knock at the least. but to change the On Board Diagnostics of any motor, all you have to change is the distributor, injectors and computer. and sometimes an adapter harness for the ecu.
