HONDA WONT BUILD BOOST PLEASE HELP!!!
I covered them with header epoxy but it burnt off. But while it was on it still didnt build. They are literally 2 tiny pinholes. And yes i have a resistor box wired in. Also, sorry about this being the wrong section. I was unaware. I will move where my boost gauge is connected. Even though it appears to me all the vacuum lines seem to meet one way or the other.
Its Lightish Red
![JStab](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![JStab](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
The line is fine, the pinholes (while very stupid) aren't causing the issue. Is your wastegate tapped in properly? Is your wastegate working? Do you have a hole in your intercooler piping? Is your blowoff valve leaking? Is your blowoff valve seated? I mean it could be a multitude of things. If you are putting "header epoxy" on a turbo manifold and expecting it to be okay, i would recommend taking it to someone who knows what the fuck they are doing.
OP,like i said post pictures of what your working with.I'm willing to bet your issue is a part installed incorrectly.
Thank you, ive been to multiple shops including wallace automotive. All agree it is a bizarre problem. I stated that I checked wastegate actuator, I used a compressor and blew into vacuum hose until it lifted. It would lift right around 10psi. I used soapy water and went all around the ic piping and checked all couplers. there are no leaks in piping. yes bov is seated and unless there is an o-ring or seal broken somewhere i dont know of everything should be okay with that.
Cool story Hansel.
![Chris28](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![Chris28](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
Is your boost gauge working correctly? Have you checked for boost leaks with compressed air?
You're using a JDM Sport turbo. that might be your problem.
Sorry Sir, I dont have a digital camera and my phone got run over and the camera is one of the things no longer working on it. However; I can assure everyone that everything is installed correctly. Not only am I not but so ignorant, but neither are the multiple mechanics that have helped me through this project. IT IS NOT AN OBVIOUS VISIBLE FIX. Thank you
"I need help! I can't find out why my blah won't blah blah blah"
"Something might be wrong. Take pictures."
"Everything is installed right, thanks but fuck off"
![Facepalm](https://www.vadriven.com/forums/images/smilies/facepalm.gif)
