How do you get a brake drum off?
Old 11-07-2010, 02:54 PM
Fanboi
Cobra4B's Avatar
Default How do you get a brake drum off?
I did a brake job on my truck as the front pads were finally getting close to the backing plates after 75,000 miles. Swapped in fresh pads, serviced the calipers, and flushed the entire system.
I wanted to take the rear drums off the check the shoes, but for the life of me I couldn't get them off on either side. I've taken them off once before, around 50,000 miles on the clock, and beat them with a mallet and wiggled them off, but this time no go. FWIW there's no threaded hole to force a bolt in against the hub.
Is there somoe other thing I'm overlooking or a special tool?
Thanks,
Brian
EDIT: Coloradofans.com says there's no fancy tool or method. Just have to hit the drum with a hammer around the hub between the wheel studs until it comes loose. Next time I'll spray it down and let it soak for a bit
Cobra4B is offline
Old 11-07-2010, 02:59 PM
baller/dickbutt#69
nftuatn's Avatar
Default Re: How do you get a brake drum off?
is the emergency brake on? if so then thats why they wont come off
nftuatn is offline
Old 11-07-2010, 03:12 PM
NAZI mod
BAN HAMMER's Avatar
blast it with piss.
BAN HAMMER is offline
Old 11-07-2010, 03:14 PM
Fanboi
Cobra4B's Avatar
No... e-brake was most definately off.
Cobra4B is offline
Old 11-07-2010, 03:23 PM
I Love to Hate
B-Well's Avatar
bigger hammer.
is there an access spot from the back?
B-Well is offline
Old 11-07-2010, 03:31 PM
Fanboi
Cobra4B's Avatar
There were two ovoid hard rubber plugs on the back side, but one was at the outer edge which looked to be for inpsectting the shoes/drum w/o taking it apart and the other one was toward the center and my inspection mirror showed the adjuster mechanism. There were no other access locations and nothing that I could get anything in and beat on it from the back side.
I guess next time I'll soak the hub with PB blaster... I think it's the inner diameter of the drum fused on the hub.
Cobra4B is offline
Old 11-07-2010, 04:51 PM
SPARKLEmotion
FObangah's Avatar
I normally soak the drum holes around the studs and hub with WD-40, wait a bit, then go for a "baby sledge" + a pry bar to direct the force right at the back edge of the drum. Gradually put more "ass" behind your blows and always move to different spots on the drum. Seems to work well for me.
A dust mask would be a good idea also.
FObangah is offline
Old 11-07-2010, 05:01 PM
certified asshole
crasy87rexsi's Avatar
crasy87rexsi crasy87rexsi crasy87rexsi crasy87rexsi crasy87rexsi crasy87rexsi
exactly PB or WD-40 and ASS.... lots of it lol
crasy87rexsi is offline
Old 11-07-2010, 05:47 PM
OV-104
Atlantis's Avatar
I had to pull a plug out in the back of my dad's ram and loosen the e-brake cable to get his off
Atlantis is offline
Old 11-07-2010, 05:50 PM
13.5:1 Poor Mans R
Kana's Avatar
Kana has disabled reputation
2lb hammer and balls. Dont be a sissy, just wail on that fucker!
Kana is offline
Quick Reply: How do you get a brake drum off?
