hub centric rings
Re: hub centric rings
Yes, you do. Unless you want your wheels to act like cams instead of wheels. There is NO reliable way to center your wheels using only the wheel studs, and that can't be argued.
If you want to use wheels that need hubcentric rings, and you don't use hubcentric rings, don't publicly admit it because you'll look stupid (and for good reason).
TheMuhFuggin♂
Seatbelt was a shitty example. How bout this LOL. Can you drive a car with as much camber as the Golf/Rabbit/Whatever Kyon had at H20 last year? Yes you can but...
You do not NEED them. You are retarded to drive without them. You'll be fucking wheel studs up/snapping them off in no time without them.
BallinthaEF
Wheels / Tires
49
10-19-2010 07:18 PM
