i did a compression test on my jdm h22
Old 10-29-2010, 11:21 AM
I Love to Hate
B-Well's Avatar
Default Re: i did a compression test on my jdm h22
take plug out
put tester in
crank 25 times
post the hella high numbers on forums for everyone to drool over
B-Well is offline
Old 10-29-2010, 11:22 AM
WEEEEEEEEEEE
TATTRAT's Avatar
have you tried blasting it with piss?
TATTRAT is offline
Old 10-29-2010, 11:32 AM
RIP DRAGVA-2016
NasTHatch's Avatar
Originally Posted by ricedoutaccord
the motor isn't stock build. the motor is sleeved and 12.1 compression pistons. the plugs look like there is corrosion on them and it also looks like compression is between the porcelain and where the metal is I will take better pics when I get off of work
I wonna know whey the plugs have that on it and there three months old
the car seems to be running a lil weird lower idle and not as good fuel millagealso should I use platinum plugs ?
bad tune/wrong gas, hide ya wife
NasTHatch is offline
Old 10-29-2010, 11:56 AM
White Devil's Avatar
OP, take out your spark plugs, then compare them to this chart.....
Or this one.
White Devil is offline
ALL ABOUT THE TORQUE
ricedoutaccord's Avatar
ricedoutaccord has disabled reputation
engine was rotated 7 times picked up a new compression tester today gonna retest to make sure gauge was correct
car was tuned by shad
premium fuel is ran in this car
nope no piss
thanks
PIC OF PLUG WITH I PHONE
ricedoutaccord is offline
Old 10-29-2010, 12:26 PM
TE37 Hoarder
slogsr@sage's Avatar
slogsr@sage slogsr@sage slogsr@sage slogsr@sage slogsr@sage slogsr@sage slogsr@sage slogsr@sage slogsr@sage slogsr@sage slogsr@sage
Is that the right heat rating for the plug? H22 and most other honda motors call for a NGK ZFR6F-11 plug.
slogsr@sage is offline
Old 10-29-2010, 12:27 PM
RIP DRAGVA-2016
NasTHatch's Avatar
nope no piss
thanks
get your car retuned after you replace the spark plugs, maybe they were on their way out when shad tuned it.
Old 10-29-2010, 12:42 PM
nope new plugs before tuned i used zfr6f-11 and just got a new set today from bap to install
third set since tune
i phone pic below
looked on ngks site yes link below
http://www.ngk.com/results_app.asp?AAIA=1170087
Old 10-29-2010, 01:01 PM
management
boredom's Avatar
boredom boredom boredom boredom boredom boredom boredom boredom boredom boredom boredom
the plugs look like they are working/operating fine. what is your concern?
boredom is offline
Old 10-29-2010, 01:05 PM
the corrosion on the plugs?
and if im using the correct ones for the motor ?
see below is a cold compression test with the new gauge
Quick Reply: i did a compression test on my jdm h22
