i need brakes help
Zerofucksgiven
![Cyanide Jello](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![Cyanide Jello](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
![Cyanide Jello is offline](https://www.vadriven.com/forums/images/statusicon/user_offline.gif)
doesn't like 1911s
![~Josh](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![~Josh](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
![~Josh is offline](https://www.vadriven.com/forums/images/statusicon/user_offline.gif)
when you say that they are dragging... do you smell the brakes burning up after driving for a short time?
![05 Gt is offline](https://www.vadriven.com/forums/images/statusicon/user_offline.gif)
try replacing the rubber brake hose it may have a clog only allowing the pads to compress and not release,i have seen this several times before ,test it simple taking it off
![dodgezilla6969 is offline](https://www.vadriven.com/forums/images/statusicon/user_offline.gif)
doesn't like 1911s
As stated in the first post the rubber line has been replaced.
try the proportioning valve? thats the only thing that has not been dealt with
![J.E.I. is offline](https://www.vadriven.com/forums/images/statusicon/user_offline.gif)
![disheeki546](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![disheeki546](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
![disheeki546 is offline](https://www.vadriven.com/forums/images/statusicon/user_offline.gif)
doesn't like 1911s
prop valves just control front to rear bias... and im getting good pressure before and after it anyways, so i'm not seeing how it could be the issue. not to mention a new one cost $140+tax at honda and they can't be bought autozone, advance, etc...
i do have two i got used, but mine looks to be in better shape then both.
if anybody could find me something saying this could even remotely be an effect of a bad prop valve i will slap one of the used ones on there this weekend and find out. other then that, im not really trying to rebleed everything just on a whim and risk getting trash or something from a used valve in the rest of the brand new system... or waste 140ish on a new one for no reason.
