i need a part but not sure what its called
Old 10-18-2008, 06:30 AM
  #41
TurboPipingSystems
thermal's Avatar
Default Re: i need a part but not sure what its called
to the OP.........
1. There is no clip that "holds the VTEC solenoid in place", unless you are talking about something internal of that solenoid itself.... What holds the VTEC solenoid in place are the hex bolts with 10mm heads.
2. The only "clip", per say, that has anything to do with the VTEC solenoid is the single wire connector. If you look at the pic below, you'll see a green/white wire (green/black wire). Notice that there is NOT a connector in between the green/white and green/black. However, you can clearly see that the two wires had been connected and insulated by a black heat shrink...... NORMALLY, that is where that factory "clip or connector" would be. Your husband's issue can be fixed the same way this picture portrays.... if we are talking about the same clip. GOODLUCK!
thermal is offline
Old 10-18-2008, 06:52 AM
  #42
VaDriven Mayhem
Lord Humongous's Avatar
So....no nudez?
Lord Humongous is offline
Old 10-18-2008, 09:28 AM
  #43
CRX
CivicRenModelX's Avatar
CivicRenModelX has disabled reputation
No. No nudes for you today.
CivicRenModelX is offline
Old 10-18-2008, 04:44 PM
  #44
hatchback91joey's Avatar
hatchback91joey has disabled reputation
[IMG][/IMG]
i think the thing that is circled is the part that i need. im tryin to get in touch with his cousin now
hatchback91joey is offline
Old 10-18-2008, 04:45 PM
  #45
Originally Posted by thermal
to the OP.........
the pic didnt how up
Old 10-18-2008, 08:27 PM
  #46
TurboPipingSystems
thermal's Avatar
... well, I can see it pretty clear and I'm sure most of us here can see it as well.
...... eitherway, the part that you circled is the VTEC oil pressure switch. So, are you looking for a clip to hook up to that? Your original harness should have it. That is a very common 2- wire connector for hondas....
thermal is offline
jacobsfather123
11-12-2008 09:22 AM
gotboosthatch
03-27-2008 07:54 PM
Joshscustoms
08-20-2007 09:44 AM
Quick Reply: i need a part but not sure what its called
